sfgh46
Apr 27, 2023Aspirant
Downstream Flashes
Downstream starts flashing every couple of weeks. Only have 1/5 internet speed, then eventually no internet when this happens. Reboot used to work, not anymore. Attached are modem logs. Let me k...
Apr 28, 2023Guru - Experienced User
Your logs indicate line issues.
Do you have a screensnip of the cable connections page?
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
