drbarney2
Jan 13, 2022Aspirant
Downstream Indicator on CM2050V
Everything seems to be working on my newly installed cable modem as it should except that the Downstream "White Light Arrow" does not stop "Blinking". Is this normal that it continues to blink becaus...
Jan 13, 2022Guru - Experienced User
Do you have a screensnip of the cable connections page and event logs?
That helps us check the line
- drbarney2Jan 13, 2022Aspirant
Please see attached/uploaded Word Doc with the Event Log and Cable Connections Downstream Data... Could not get a Screen Shot of all of the Data...
- plemansJan 13, 2022Guru - Experienced User
Your line's got some issues.
Try removing any splitters or signal attenators form the line.
Directly attach the modem to right where the coax comes into the home.
Check the connections for loose/corroded/old/bad/cheap connections and remove them if you have them.
I am directly connected to where the coax comes into my home... and it then goes to my Wi-Fi router... there my be a splitter in the CAT 5 Panel that the xfinity tech guy installed when they upgraded the cable from the street box to my home's CAT 5 Panel. In the CAT 5 Panel is where it splits the incoming cable to different coax cable access points going to mulitple rooms in my home.
Does this info help?
