drbarney2
Jan 13, 2022Aspirant
Downstream Indicator on CM2050V
Everything seems to be working on my newly installed cable modem as it should except that the Downstream "White Light Arrow" does not stop "Blinking". Is this normal that it continues to blink becaus...
Jan 13, 2022Guru - Experienced User
Do you have a screensnip of the cable connections page and event logs?
That helps us check the line
drbarney2
Please see attached/uploaded Word Doc with the Event Log and Cable Connections Downstream Data... Could not get a Screen Shot of all of the Data...
