drbarney2
Jan 13, 2022Aspirant
Downstream Indicator on CM2050V
Everything seems to be working on my newly installed cable modem as it should except that the Downstream "White Light Arrow" does not stop "Blinking". Is this normal that it continues to blink becaus...
Jan 13, 2022Guru - Experienced User
Your line's got some issues.
Try removing any splitters or signal attenators form the line.
Directly attach the modem to right where the coax comes into the home.
Check the connections for loose/corroded/old/bad/cheap connections and remove them if you have them.
drbarney2
I am directly connected to where the coax comes into my home... and it then goes to my Wi-Fi router... there my be a splitter in the CAT 5 Panel that the xfinity tech guy installed when they upgraded the cable from the street box to my home's CAT 5 Panel. In the CAT 5 Panel is where it splits the incoming cable to different coax cable access points going to mulitple rooms in my home.
Does this info help?
- plemansJan 13, 2022Guru - Experienced User
Cat5 shouldn't matter. It should be the coax.
- drbarney2Jan 13, 2022Aspirant
Thak you for your efforts... I cannot do anything regarding the Cable. A new cable was installed from the xfinity box at the street where it branches off to multiple homes on my street, and a new cable was run from the xfinity street box to my home's access point. There is not any way to run new cable internally as this would be a huge undertaking and cost...
My download seems to be working... Download from my Router = 356.5; Upload = 12.7
Download from xfinity direct = 179.9; Upload = 12.49.
