ATVrider's avatar
Jan 19, 2017
Downstream LED flashing
I have the Nighthawk c7000 cable modem router. It was working fine since I bought it in April 2016 until recently. For the past few weeks the downstream green light has been flashing. I restarted and ...
  • DarrenM's avatar
    Jan 23, 2017
    Hello ATVrider
    it means the modem is scanning for a downstream channel I would check with your ISP see if they can look at there tools to see if your levels are off or that something is wrong with the connection.
    DarrenM
