ATVrider
Jan 19, 2017Tutor
Downstream LED flashing
I have the Nighthawk c7000 cable modem router. It was working fine since I bought it in April 2016 until recently. For the past few weeks the downstream green light has been flashing. I restarted and ...
- Jan 23, 2017
Hello ATVrider
it means the modem is scanning for a downstream channel I would check with your ISP see if they can look at there tools to see if your levels are off or that something is wrong with the connection.
DarrenM
ATVrider
Jan 24, 2017Tutor
Thank you so much. The cable provider came out today, changed the lines outside because they looked worn, now the light stopped flashing and speeds are back up.
