Kim1888
Jun 25, 2022Aspirant
Downstream light keeps blinking
Hello how did you fix this?
Jun 25, 2022Guru - Experienced User
What NG modem model are you referring too?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- Kim1888Jun 25, 2022AspirantThe model is c7000v2
- plemansJun 26, 2022Guru - Experienced User
If the downstream light is blinking, it means only 1 channel is locked and its searching for more channels.
You need to post a screen snip of the cable connections page and the event logs for us to help you better.
But you can start with a few troubleshooting tips.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
