TheWolverine97
Nov 04, 2020Follower
Downstream light, Upstream light, and Online light
My Downstream light keeps blinking, my upstream light is off and my online light is off as well. I have disabled my AT&T WiFi so the signal are not competing with each other. I have also did a system...
Sorensen_kk
Nov 08, 2020Aspirant
Once the modem syncs on a downstream channel, the Downstream light will go solid green and the Upstream light will start blinking green. The Upstream light will go solid green once it has established a connection. Depending on your service, additional channels may bond together.
Nov 09, 2020Guru - Experienced User
Sorensen_kk Not sure if you're thread jumping and wanting help or if you're trying to help.
