Koz1614
May 09, 2020Tutor
Downstream power level good, Upstream bad
Hey all, A week or so ago, Xfinity came out and fixed the node/lines for my neighborhood. After the upgrade, my signal levels were dramatically improved. My downstream power level went from -6 dB...
May 10, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are not coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
