Landrovers
Oct 03, 2019Follower
Downstream, upstream and internet LEDs blinking
Okay so as the title suggests my router/modem’s Upstream, Downstream and Internet LED lights are blinking green. After turning off my router/modem and turning it back on this started happening. My WiFi does not show up at all(though my extender does but it’s not connected to my WiFi) I have tried resetting it and turning it off and on, I’ve pressed the WiFi button but that doesn’t seem to work. The power LED is solid green. Any help would be greatly appreciated.
1 Reply
Try pressing the reset button for 15 seconds then let go with the ISP coax service cable disconnected from the modem. If it resets, look at your wireless devices and see if you see any default SSID name appearing.
If you do, might walk thru the setup wizard or configure the modems wifi for your custome SSID name and PW.
Reconnect the ISP coax cable to the modem.
If you don't see any wifi after the reset, possible the modem could be faulty.
