alexj319
Mar 09, 2020Guide
Dropping internet multiple times a day for a few minutes - Critical Logs Interpretation
Hi all, I have been struggling with this for the past few months. When my internet drops, neither the modem or the router show that there has been an interruption in service. I do know that power...
- Mar 09, 2020
if the new gateway doesn't change anything, your isp needs to check your line.
Your upstream power levels are a little high and you've got a few error in your signal.
Mar 09, 2020Guru - Experienced User
Also get a screen snip of the modem's connections page. it shows the connection back to the isp.
alexj319
Mar 09, 2020Guide
I do not know if it will confound things, but after the original post, I factory reset the modem again.
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 465000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 8 | 465000000 Hz | 3.2 dBmV | 38.2 dB | 171297351 | 0 | 0 |
| 2 | Locked | QAM256 | 9 | 471000000 Hz | 3.2 dBmV | 38.3 dB | 171240487 | 0 | 0 |
| 3 | Locked | QAM256 | 10 | 477000000 Hz | 3.4 dBmV | 38.2 dB | 171244134 | 0 | 0 |
| 4 | Locked | QAM256 | 11 | 483000000 Hz | 3.3 dBmV | 38.1 dB | 171247255 | 0 | 0 |
| 5 | Locked | QAM256 | 12 | 489000000 Hz | 3.4 dBmV | 38.0 dB | 171250613 | 0 | 0 |
| 6 | Locked | QAM256 | 13 | 495000000 Hz | 3.5 dBmV | 38.2 dB | 171254787 | 0 | 0 |
| 7 | Locked | QAM256 | 14 | 519000000 Hz | 3.8 dBmV | 37.9 dB | 171259271 | 0 | 0 |
| 8 | Locked | QAM256 | 15 | 525000000 Hz | 3.7 dBmV | 37.9 dB | 171262507 | 0 | 0 |
| 9 | Locked | QAM256 | 16 | 531000000 Hz | 3.8 dBmV | 37.8 dB | 171265878 | 0 | 0 |
| 10 | Locked | QAM256 | 17 | 537000000 Hz | 3.9 dBmV | 37.8 dB | 171270047 | 0 | 0 |
| 11 | Locked | QAM256 | 18 | 543000000 Hz | 4.3 dBmV | 37.9 dB | 171267892 | 0 | 0 |
| 12 | Locked | QAM256 | 19 | 549000000 Hz | 4.2 dBmV | 37.9 dB | 171271593 | 0 | 0 |
| 13 | Locked | QAM256 | 20 | 555000000 Hz | 4.4 dBmV | 37.9 dB | 171275647 | 0 | 0 |
| 14 | Locked | QAM256 | 21 | 561000000 Hz | 4.5 dBmV | 37.8 dB | 171278819 | 0 | 0 |
| 15 | Locked | QAM256 | 22 | 567000000 Hz | 4.4 dBmV | 37.8 dB | 171282754 | 0 | 0 |
| 16 | Locked | QAM256 | 23 | 573000000 Hz | 4.6 dBmV | 37.0 dB | 171286464 | 0 | 0 |
| 17 | Locked | QAM256 | 24 | 579000000 Hz | 4.6 dBmV | 37.3 dB | 171289921 | 0 | 0 |
| 18 | Locked | QAM256 | 25 | 585000000 Hz | 4.7 dBmV | 37.3 dB | 171294051 | 0 | 0 |
| 19 | Locked | QAM256 | 26 | 591000000 Hz | 5.1 dBmV | 36.5 dB | 171297933 | 0 | 0 |
| 20 | Locked | QAM256 | 27 | 597000000 Hz | 5.3 dBmV | 36.9 dB | 171301694 | 0 | 0 |
| 21 | Locked | QAM256 | 28 | 603000000 Hz | 5.2 dBmV | 37.8 dB | 171305274 | 0 | 0 |
| 22 | Locked | QAM256 | 29 | 609000000 Hz | 5.1 dBmV | 37.7 dB | 171309094 | 0 | 0 |
| 23 | Locked | QAM256 | 30 | 615000000 Hz | 5.3 dBmV | 37.8 dB | 171311834 | 0 | 0 |
| 24 | Locked | QAM256 | 31 | 621000000 Hz | 5.4 dBmV | 37.8 dB | 171316251 | 0 | 0 |
| 25 | Locked | QAM256 | 32 | 627000000 Hz | 5.7 dBmV | 37.7 dB | 171320433 | 0 | 0 |
| 26 | Locked | QAM256 | 33 | 633000000 Hz | 5.6 dBmV | 37.8 dB | 171323223 | 0 | 0 |
| 27 | Locked | QAM256 | 34 | 639000000 Hz | 5.0 dBmV | 37.8 dB | 171327704 | 0 | 0 |
| 28 | Locked | QAM256 | 35 | 645000000 Hz | 5.0 dBmV | 37.5 dB | 171331399 | 0 | 0 |
| 29 | Locked | QAM256 | 36 | 651000000 Hz | 5.1 dBmV | 37.6 dB | 171333273 | 0 | 0 |
| 30 | Locked | QAM256 | 37 | 657000000 Hz | 5.0 dBmV | 37.6 dB | 171334956 | 0 | 0 |
| 31 | Locked | QAM256 | 38 | 663000000 Hz | 5.0 dBmV | 37.6 dB | 171333886 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 45 | 36500000 Hz | 50.5 dBmV |
| 2 | Locked | ATDMA | 46 | 30100000 Hz | 51.8 dBmV |
| 3 | Locked | ATDMA | 47 | 23700000 Hz | 52.0 dBmV |
| 4 | Locked | ATDMA | 48 | 17300000 Hz | 51.8 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 48 | 805000000 Hz | 4.4 dBmV | 35.3 dB | 1168 ~ 2927 | 5559116 | 2925416 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 1.2 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
Current System Time: Mon Mar 09 10:43:42 2020 System Up Time: 1:05:55
