alexj319
Mar 09, 2020Guide
Dropping internet multiple times a day for a few minutes - Critical Logs Interpretation
Hi all, I have been struggling with this for the past few months. When my internet drops, neither the modem or the router show that there has been an interruption in service. I do know that power...
- Mar 09, 2020
if the new gateway doesn't change anything, your isp needs to check your line.
Your upstream power levels are a little high and you've got a few error in your signal.
Mar 09, 2020Guru - Experienced User
Like FURRYe38 said, check your coax connectors and lines. A cheap connector/splitter can cause many issues.
Let it run for a while and re-post that connections page. If this is fresh off a factory reset, you're not going to see the errors/problems. If its intermittent, wait until you have an issue, then log into this page and screen snip it.
alexj319
Mar 09, 2020Guide
The drops have been occurring all day. They seem to be getting worse, shorter intervals between drops, and longer intervals before the internet comes back.
I have now connected a new gateway (vs. my modem & router combo), and will report back if that changes anything.
Here is the connection page and logs.
Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream OFDM Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream OFDMA Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time: Mon Mar 09 15:54:27 2020 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
System Up Time: 0:04:13 |
- plemansMar 09, 2020Guru - Experienced User
- alexj319Mar 09, 2020Guide
Thank you for all the help. The new gateway hasn't changed anything as far as I can tell. Have had a few drops, but things tend to settle down at night (i.e. I have never had an issue streaming tv shows after dinner).
A technician is on their way tomorrow morning, and I will update this thread if they can resolve it, and what the issue was.
- FURRYe38Mar 10, 2020Guru - Experienced User
You service line needs to be looked at.
Let us know how it goes. Be sure to put back the orginal modem or have the technician put the original modem back and ensure it's working right.
alexj319 wrote:Thank you for all the help. The new gateway hasn't changed anything as far as I can tell. Have had a few drops, but things tend to settle down at night (i.e. I have never had an issue streaming tv shows after dinner).
