fd1
Nov 30, 2020Aspirant
Dropping of internet connection
In recent days my Cox cable internet connection has been lost a couple of times for a number of hours straight but both times it came right by itself. Cox is advising that there have been no known ou...
Dec 01, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- fd1Dec 14, 2020Aspirant
FURRYe38 issue has been resolved by ISP after local troubleshooting. It appeared that the ISP's splitter on the outside of the property was faulty and was causing these increased levels.
- FURRYe38Dec 14, 2020Guru - Experienced User
Glad you got it fixed. Please mark your thread as solved, so others will know.
Enjoy.
