Marasmic's avatar
Marasmic
Dropping packets and extremely slow internet especially during peak hours
Hey,
Can someone take a look at my modem stats to see if anything looks out of whack? I don't know what most of this means, but I was hoping someone here would know. The modem has been running for about 15 days now. I've been getting extremely high ping, dropped packets and slow internet especially during peak hours. I'm paying for 75 m/bits used to get 85ish and now I'm getting 5 - 20. Any help you guys can offer would be appreciated. Thanks!
  • plemans's avatar
    You have a lot of errors in your line.
    If you have any splitters, attenuators, amplifiers in the coax line, remove them. Also check the line for kinks, damage, poor/cheap connectors, bad lines, etc.
    If you check all that and are still getting those levels, the ISp needs to check the line.
  • FURRYe38's avatar
    Have the ISP check the signal and line quality UP to the modem.
    Be sure there are no coax cable line splitters in the between the modem and ISP service box.
    Be sure your using good quality RG6 coax cable up to the modem.
    Be sure to power OFF the modem for 1 minute them back ON.
    Be sure to check pings with out a external router connected to the modem. Use a wired PC directly connected to the modem.
    • Marasmic's avatar
      Marasmic
      I've done everything i can inside. Nothing has changed with my wiring and the ISP had me reset my modem about a million times. I've been trying to get a tech out, but they're really giving me the run around. I guess it must be something with their wiring.
      • plemans's avatar
        many times the junction box on the house is/can be opened without damaging anything. You can check the connection there and see if there's issues.
        If not, then the isp does need to check it.
