rhill1959
Jun 25, 2020Aspirant
dropping wifi
Hi, I'll start out by saying I don't know much about wifi or networking. My problem is wifi connected devices will stop working. For example on the iphone it stops working, I'll try the other wifi...
Jun 25, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
- rhill1959Jun 26, 2020Aspirant
Thanks for the pointers. I did the channel changes for both 2.4 and 5 ghz. I checked my advanced settings > wireless settings. Implicit Beamforming was already on, and I don't have options for either MIMO or WMM.
