mjphillips
Apr 20, 2021Aspirant
Drops internet connection if left for an hour
Hi, we're using a refurbed C7000-200NAB modem/router combo. (This was a replacement for an earlier C7000 that was having the same problem. I can't even find a phone number for Netgear support anymore...
Apr 20, 2021Guru - Experienced User
Does this happen with a different wired PC or laptop?
Happen with any wifi devices connected as well?
- mjphillipsApr 20, 2021Aspirant
Thanks Furry...
It seems to happen with one other computer that's left on sometimes. There are no wireless devices on the network. Hope this helps... tx
- FURRYe38Apr 20, 2021Guru - Experienced User
I would check with the PCs Mfr for help, support and information regarding this.
Thanks again. I did check with them when it was happening with the original router, but I guess I have some more leverage now. (Apple's "genius" pool seems to have become a bit diluted :-(
Wish me luck! and thank you for the speedy responses!
