mjphillips
Apr 20, 2021Aspirant
Drops internet connection if left for an hour
Hi, we're using a refurbed C7000-200NAB modem/router combo. (This was a replacement for an earlier C7000 that was having the same problem. I can't even find a phone number for Netgear support anymore...
mjphillips
Thanks Furry...
It seems to happen with one other computer that's left on sometimes. There are no wireless devices on the network. Hope this helps... tx
Apr 20, 2021Guru - Experienced User
I would check with the PCs Mfr for help, support and information regarding this.
- mjphillipsApr 20, 2021Aspirant
Thanks again. I did check with them when it was happening with the original router, but I guess I have some more leverage now. (Apple's "genius" pool seems to have become a bit diluted :-(
Wish me luck! and thank you for the speedy responses!
- FURRYe38Apr 20, 2021Guru - Experienced User
If samething with this one PC is happening on two different modems/routers, then the problem will be with this one PC.
Good Luck.
- plemansApr 21, 2021Guru - Experienced User
Easy check. Buy a usb->ethernet adapter or a wifi card and connect the computer that route. See if it stays connected. It might not if its an issue with the computers software but if its a driver/ethernet card issue, it could fix it.
