Shajee_j
Jun 20, 2021Follower
Dynamic to Static
Hey, I want To Change My Ip Address From Dynamic To Static And Open Some Ports For Better Gaming Experience Can Someone Help. Ports TCP: 80, 443, 3478, 3479, 3480 UDP: 3478, 3479
antinode
Jun 20, 2021Guru
> [...] I want To Change My Ip Address From Dynamic To Static [...]
Talk to your ISP.
> [...] And Open Some Ports For Better Gaming Experience [...]
What led you to believe that "Open Some Ports" would lead to "Better
Gaming Experience"?
Look for "port forwarding" in your router's user manual?
> Model: CM500|16x4 DOCSIS 3.0 Cable Modem
There's nothing your modem can do about either item.
antinode
Jun 20, 2021Guru
My first response might have been too hasty.
What, exactly, do you mean by "My Ip Address"? Do _you_, personally,
have an IP address, or did you mean the external/public IP address of
your (unspecified) router's WAN/Internet interface (which is what I
assumed), or the IP address of some computer/device on your LAN (which
you'd need to fix, if you wanted to use port forwarding), or what?
Note that many people get along well enough using a dynamic
external/public IP address with DDNS.
In any case, I wouldn't expect the type of external/public IP address
you have to affect your "Gaming Experience" (whatever that means).
