tweeetycrazee
Jul 10, 2022Follower
echo dot plugs and lights
I restarted my modem and now I can no longer connect to the echo plugs and lights. It still connects to the echo dot itself. Thinking on this.. I can no longer connect to my printer wirelessly. Pl...
Jul 10, 2022Guru - Experienced User
You gave us nothing to go off.
What NG product are you referring too?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
