corvairbob
Mar 02, 2024Tutor
eero 6 router question
ok i have comcast and i now have frontier fiber at the pole and ready to install when i order it. they provide a router called the amazon eero 6 router. so how will that mate up with my house networ...
Mar 02, 2024Guru - Experienced User
Any brand that has WiFi 6 will out perform the gateway modem. Even a NG MK60, 70 or 80 series will.
corvairbob
Mar 03, 2024Tutor
can anyone tell me if i can get these eero 6 routers say from ebay or amazon and have them connect to the one i get from frontier? i do not yet know just how many frontier will leave when they do the install on march 11 2024. i figure at least one but if they do leave 3 as most come in a group of 3 that may be plenty for me. but if they only leave 1 can i get some more myself and connect them?
thanks
- plemansMar 03, 2024Guru - Experienced User
I don't have eero so you might have better luck on their forums. but from my readings, the devices can function as either a router or a satellite. You'd just want to ensure you get one that is compatible. So I'd wait to see what version and how many you get from frontier before buying anything.
- corvairbobMar 04, 2024Tutor
thanks everyone for the help. i tried the ewelink forums and so far no one has replied. but the eero support did tell me the ewelink switches should connect up to the eero 6 just fine. so in a couple of weeks we will find out for sure. i will let you all know if they do and if not i will try to connect them again to the netgear combo unit and see if that connects to the eero 6 router in router mode and work. the eero 6 support thinks the netgear router will pair up with the eero 6 router if i plug the eero 6 into that router. so that the netgear extender will be seen by the netgear router and then transfer thru the lan to the eero 6 and then wifi to my phone. but again i will soon find out when they connect the fiber to my home in a few weeks. thanks
- plemansMar 04, 2024Guru - Experienced User
The C3700 is a cable modem/router. it won't work with the fibre.
