corvairbob
Mar 02, 2024Tutor
eero 6 router question
ok i have comcast and i now have frontier fiber at the pole and ready to install when i order it. they provide a router called the amazon eero 6 router. so how will that mate up with my house networ...
Mar 03, 2024Guru - Experienced User
I don't have eero so you might have better luck on their forums. but from my readings, the devices can function as either a router or a satellite. You'd just want to ensure you get one that is compatible. So I'd wait to see what version and how many you get from frontier before buying anything.
corvairbob
Mar 04, 2024Tutor
thanks everyone for the help. i tried the ewelink forums and so far no one has replied. but the eero support did tell me the ewelink switches should connect up to the eero 6 just fine. so in a couple of weeks we will find out for sure. i will let you all know if they do and if not i will try to connect them again to the netgear combo unit and see if that connects to the eero 6 router in router mode and work. the eero 6 support thinks the netgear router will pair up with the eero 6 router if i plug the eero 6 into that router. so that the netgear extender will be seen by the netgear router and then transfer thru the lan to the eero 6 and then wifi to my phone. but again i will soon find out when they connect the fiber to my home in a few weeks. thanks
- plemansMar 04, 2024Guru - Experienced User
The C3700 is a cable modem/router. it won't work with the fibre.
- corvairbobMar 04, 2024Tutor
that is strange because the frontier video show connecting the cable modem router unit to the eero 6 and going with that. plus i did find 2 YT vides that showed connecting the eero 6 to the back of the router modem and going with it. and eero 6 website seems to think it will connect. however the only way i will know for sure is when the install guy gets here and tells me it will not work, but the eero 6 website did say if the netgear will not work not to worry the eero 6 units will just replace that anyway. they also said if frontier only gives me 1 unit that i can amazon or ebay more and they will mesh just fine.
i'm hoping the netgear will work with the eero 6 so i do not have to reset up my cameras they are a pain to set up and i have 5 nvrs to reset if the eero 6 will not let me keep the netgear in the loop. i have a hub where the netgear combo is now and the combo is connected to that hub and everything works good so i hope the eero 6 will just plug into that hub and i can just connect the phone to the eero 6 and it will mesh into the network and let me see the cameras, we will soon find out.
i will find out march11 or so when they stop out and install the modem to their system and set me up at least 1 eero 6 router. i will let you know how it all goes. frontier said to download the app but i will wait for the install to do that as it takes a few minutes and the install may want to help with it to get it setup. thanks
- FURRYe38Mar 04, 2024Guru - Experienced User
Might configure the NG gateway modem into modem only mode for your wifi router system:
https://kb.netgear.com/27191/How-to-set-the-cable-modem-router-to-be-on-modem-only
