Nikko1075
Jul 08, 2020Aspirant
eero won't reconnect after power outage?
eero connected to a CM 1150V in Port 1. Works great until we have a power outage, then it won't come back online. The only way to get it to work is to unplug all the ports and power up the modem. ...
Jul 08, 2020Guru - Experienced User
Contact the mfr for Eero and get help and information about there product there.
Nikko1075
I did contact eero, that was the only way I was able to connect it initially. They said they had heard of this issue before with Netgear and I needed to reach out to them for a perm soution.
- FURRYe38Jul 08, 2020Guru - Experienced User
Try powering OFF the modem and Eero router for 1 minute then back ON with the modem first then the Eero router. a reset maybe needed of the router.
Try swapping out the lan cable between the modem and router. CAT6 is recommended.
Nikko1075 wrote:I did contact eero, that was the only way I was able to connect it initially. They said they had heard of this issue before with Netgear and I needed to reach out to them for a perm soution.
