Nikko1075
Jul 08, 2020Aspirant
eero won't reconnect after power outage?
eero connected to a CM 1150V in Port 1. Works great until we have a power outage, then it won't come back online. The only way to get it to work is to unplug all the ports and power up the modem. ...
antinode
Jul 08, 2020Guru
> eero connected to a CM 1150V in Port 1. [...]
"eero" is a company, which makes more than one product. This is some
model of router?
> [...] After it's connected, I can pug everything else back in. [...]
What, exactly, is "everything else"? And why do you expect to be
able to plug anything else into a CM1150V modem?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for the
description of "Ethernet ports 1-4", and the following:
Note Your cable modem comes with plugs that cover Ethernet ports
2, 3 and 4. For moreinformation about Ethernet ports 2, 3,
and 4, visit netgear.com/support/product/CM1150V.
Why is "everything else" connected to your modem, and not to your
router?
