Nikko1075
Jul 08, 2020Aspirant
eero won't reconnect after power outage?
eero connected to a CM 1150V in Port 1. Works great until we have a power outage, then it won't come back online. The only way to get it to work is to unplug all the ports and power up the modem. ...
Nikko1075
I did contact eero, that was the only way I was able to connect it initially. They said they had heard of this issue before with Netgear and I needed to reach out to them for a perm soution.
Jul 08, 2020Guru - Experienced User
Try powering OFF the modem and Eero router for 1 minute then back ON with the modem first then the Eero router. a reset maybe needed of the router.
Try swapping out the lan cable between the modem and router. CAT6 is recommended.
Nikko1075 wrote:I did contact eero, that was the only way I was able to connect it initially. They said they had heard of this issue before with Netgear and I needed to reach out to them for a perm soution.
