Rraderskiy's avatar
Rraderskiy
Follower
Feb 23, 2020
Emailing issue Nighthawk C7800
Hello... since I switched to this new modem/ router Outlook on Dell lap top will not send any emails . It will send couple and all rest will get stock in Outbox . I will have to reset PC to make them move. Then it will repeat same thing. I never experienced that with my old modem/ router .... Any settings needs to be changed ? Thanks
1 Reply
  • FURRYe38's avatar
    Is the PC using a static IP address? Or Set to Auto Obtain IP addressing on it's networking adapter?
    Is the PC wire or wireless connected to the modem?
    What OS is this PC using?
    Do other PCs or devices have the same problem?
    is the modem using detected ISP DNS or a custom DNS address?
