StarboardBow
Jul 04, 2017Star
embedded web interface fails after week runtime
Have C3700-100NAS, currently running firmware V2.02.08 upgraded thru Comcast xFinity ISP. Can normally connect to unit's embedded web interface both thru default IP 192.168.0.1 and URL http://rou...
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello StarboardBow
Try using the cable interface ip which is 192.168.100.1 see if that will come up sometime from that page you can get to the routers WebUi.
DarrenM
StarboardBow
Jul 07, 2017Star
DarrenM --
No joy.
IP 192.168.100.1 has same result, failing to connect to web interface neither thru either 2.4Ghz or 5Ghz WiFi frequencies nor Ethernet cable -- latest recurrence of web interface failing to connect appears to have happened some time within the past six hours.
