Cornchips
Jul 11, 2020Follower
End of life for C7000?
My Nigthawk C7000, which I bought in 2016, has fail intermittently for the last few months. Each time the cable company or I have to reboot it to get it going again. Also each time it goes down I nev...
Jul 11, 2020Guru - Experienced User
Log into the cable connections page on it and take a screen snip of it. Post that back here with a screen snip of the logs.
that helps check your connection.
If you have any splitters, attenuators, or amplifiers in line, remove them. They can cause issues.
hard part about internet service is its more finicky than simple cable tv. Its need certain power levels.
this would also be the forum for the C7000
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
