ThomasCruise100
Aug 26, 2024Tutor
"ERR_SSL_BAD_RECORD_MAC_ALERT" CAX80 cable/modem
On certain sites I constantly get "ERR_SSL_BAD_RECORD_MAC_ALERT", or like today on BestBuy's website it would crash or error out as well with like error 404 content not found. If I go to my parent...
Aug 26, 2024Guru - Experienced User
What browser are you using?
Happens or seen in different browsers like MS-Edge, Firefox or Opera?
Happens if you ethernet connect your PC to the modem?
Happens with other devices with same site?
Armor, Smart Parental Controls or Circle, Traffic Meter.
ThomasCruise100
Aug 26, 2024Tutor
I primarily use MS Edge. I tried Google Chrome and I got the same issue (to be fair Edge and Chrome use the same base chromium or w/e it is)
The error does not occur if I connect via ethernet directly to router, only on my home wifi/router (other places I do not get error).
I will test other devices at home in the next few days and report back.
I have tried disabling various internet security/malware settings and programs to no avail. (again, why would it work at other places but not home wifi?)
I just did a factory reset of the router and set up last night and still got the error.
- FURRYe38Aug 27, 2024Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router- ThomasCruise100Aug 29, 2024Tutor
I am getting the same error on mobile. also noticing a lot of hic-ups in general using the internet with things like failure to upload images to sites, failure to upload video, sites not loading or taking very long to reload etc.
Cable Diagnostic
Status: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Thu Aug 29 12:19:48 2024Startup Procedure
Acquire Downstream Channel: 435 MHz Locked
Connectivity State: OK Operational
Boot State: OK Operational
Security: Enabled BPI+
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 4 435000000 Hz 2.5 dBmV 44.6 dB 2074 749
2 Locked 256 QAM 1 417000000 Hz 2.4 dBmV 44.5 dB 4 0
3 Locked 256 QAM 2 423000000 Hz 2.3 dBmV 44.5 dB 9 0
4 Locked 256 QAM 3 429000000 Hz 2.5 dBmV 44.5 dB 4 0
5 Locked 256 QAM 5 441000000 Hz 2.3 dBmV 44.5 dB 5 0
6 Locked 256 QAM 6 447000000 Hz 1.9 dBmV 44.2 dB 6 0
7 Locked 256 QAM 7 453000000 Hz 1.6 dBmV 44.2 dB 17 0
8 Locked 256 QAM 8 459000000 Hz 1.6 dBmV 44.1 dB 9 0
9 Locked 256 QAM 9 465000000 Hz 1.6 dBmV 44.1 dB 6 0
10 Locked 256 QAM 10 471000000 Hz 1.4 dBmV 42.9 dB 7 0
11 Locked 256 QAM 11 477000000 Hz 1.6 dBmV 33.7 dB 54 0
12 Locked 256 QAM 12 483000000 Hz 1.7 dBmV 34.7 dB 5 0
13 Locked 256 QAM 13 489000000 Hz 1.5 dBmV 43.5 dB 77 0
14 Locked 256 QAM 14 495000000 Hz 1.6 dBmV 43.1 dB 91 6
15 Locked 256 QAM 15 507000000 Hz 1.9 dBmV 43.7 dB 2 0
16 Locked 256 QAM 16 513000000 Hz 1.7 dBmV 43.1 dB 3 0
17 Locked 256 QAM 17 519000000 Hz 1.8 dBmV 43.4 dB 9 0
18 Locked 256 QAM 18 525000000 Hz 2 dBmV 44 dB 8 0
19 Locked 256 QAM 19 531000000 Hz 1.9 dBmV 44 dB 46 5
20 Locked 256 QAM 20 537000000 Hz 1.5 dBmV 43.8 dB 2 0
21 Locked 256 QAM 21 543000000 Hz 1.7 dBmV 43.8 dB 0 0
22 Locked 256 QAM 22 549000000 Hz 2.1 dBmV 44.1 dB 0 0
23 Locked 256 QAM 23 555000000 Hz 2.2 dBmV 43.2 dB 0 0
24 Locked 256 QAM 24 561000000 Hz 2.1 dBmV 43.6 dB 1 0
25 Locked 256 QAM 25 567000000 Hz 1.8 dBmV 43.7 dB 11 0
26 Locked 256 QAM 26 573000000 Hz 1.7 dBmV 38.3 dB 16 0
27 Locked 256 QAM 27 579000000 Hz 1.7 dBmV 40.6 dB 9 0
28 Locked 256 QAM 28 585000000 Hz 1.7 dBmV 35.7 dB 0 0
29 Locked 256 QAM 29 591000000 Hz 1.9 dBmV 37.8 dB 0 0
30 Locked 256 QAM 30 597000000 Hz 2.1 dBmV 38.2 dB 3 0
31 Locked 256 QAM 31 603000000 Hz 1.9 dBmV 36 dB 7 0
32 Locked 256 QAM 32 609000000 Hz 1.5 dBmV 38.8 dB 3 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 1 5120 Ksym/sec 16400000 Hz 35.8 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 22800000 Hz 35.0 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 29200000 Hz 35.0 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 35600000 Hz 34.8 dBmV
5 Locked ATDMA 5 2560 Ksym/sec 40400000 Hz 37.8 dBmV
6 Locked ATDMA 6 2560 Ksym/sec 10400000 Hz 39.5 dBmV
7 Not Locked Unknown 0 0 0 0.0
8 Not Locked Unknown 0 0 0 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 0 ,1 ,2 ,3 193 805000000 Hz 3.28 dBmV 43.2 dB 1108 ~ 2987 2595037349 819525827 0
2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
Event Log
Time Priority Description
Tue Aug 27 17:24:32 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 27 17:11:52 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 27 17:10:13 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 27 17:08:52 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 27 17:08:07 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Tue Aug 27 17:02:11 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Mon Aug 26 00:52:37 2024 Critical No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Mon Aug 26 00:52:31 2024 Critical SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Mon Aug 26 00:52:31 2024 Notice DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Mon Aug 26 00:52:23 2024 Notice TLV-11 - unrecognized OID;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:03:03 1970 Notice Honoring MDD; IP provisioning mode = IPv6
Thu Jan 1 00:03:00 1970 Critical No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:02:42 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:01:05 1970 Warning Lost MDD Timeout;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Thu Jan 1 00:00:56 1970 Critical SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;Event Log
Time Priority Description Tue Aug 27 17:24:32 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Tue Aug 27 17:11:52 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Tue Aug 27 17:10:13 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Tue Aug 27 17:08:52 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Tue Aug 27 17:08:07 2024 Notice (6) CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Tue Aug 27 17:02:11 2024 Notice (6) CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Mon Aug 26 00:52:37 2024 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Mon Aug 26 00:52:31 2024 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Mon Aug 26 00:52:31 2024 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Mon Aug 26 00:52:23 2024 Notice (6) TLV-11 - unrecognized OID;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:03:03 1970 Notice (6) Honoring MDD; IP provisioning mode = IPv6 Thu Jan 1 00:03:00 1970 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:90:f0:1d:01:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:02:42 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:01:05 1970 Warning (5) Lost MDD Timeout;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Thu Jan 1 00:00:56 1970 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:18:65:2c:65:c3;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Aug 29, 2024Guru - Experienced User
Seeing some correctables and un-correctables that should be mostly zeros. Channel 1 seems to have the most. Not terrible though.
Power levels are good.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/Who is the ISP?
Are you seeing this with both wireless and ethernet connected devices?
