G_Threepwood
Mar 23, 2019Aspirant
Error code -50 - Large file transfer
Hey,
I am getting this strange error on the mac. I am connected to a drive connected via USB to the router. If I attempt to transfer smaller files, then it works fine. If I attempt to do la...
antinode
Mar 23, 2019Guru
Mac OS version?
> I am connected to a drive connected via USB to the router. [...]
What is your "a drive"? Size? Format/file-system? What happens if
you connect it directly to your (unspecified) Mac?
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
That's "the router"? Firmware version?
> [...] smaller files [...] larger [...]
"smaller"/"larger" than what? What kind of "files"? Space available
on your "a drive"?
