G_Threepwood
Mar 23, 2019Aspirant
Error code -50 - Large file transfer
Hey,
I am getting this strange error on the mac. I am connected to a drive connected via USB to the router. If I attempt to transfer smaller files, then it works fine. If I attempt to do la...
G_Threepwood
Mar 25, 2019Aspirant
Hey,
OS X 10.13.5
8TB , NTFS - If I connect it directly to the mac I can see the files but can't upload due to the NTFS file system. Works fine in Windows.
C7000|Nighthawk - AC1900 WiFi Cable Modem Router - Latest Firmware ( purchased it about 3 weeks ago)
Files under 1 mb work - Files over 1 GB don't seem to. 6TB free space. Movie files, sound files, etc.
I was able to get this to work only after restarting the computer and manually connecting to the server again. It is annoying that it seems to happen frequently though and the only solution is to do a full restart.
G_Threepwood
Mar 31, 2019Aspirant
Still no solution.
