colnhausen
Feb 09, 2019Aspirant
Error: "Login failed. The router response timed out"
I am attempting to update firmware. My current version is 1.01.32. I'm not able to do it via mobile device.
I am trying to do it via desktop/ethernet connection. When I attempt to login to the...
antinode
Feb 09, 2019Guru
> I am attempting to update firmware. [...]
On what?
> Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
That's a cable-TV modem+router. Only your ISP can update its
firmware.
> I am trying to do it via desktop/ethernet connection. [...]
What's your "desktop"?
> [...] When I attempt to login to the router, [...]
How, exactly? Some web browser? Using some URL?
> [...] I get "Login failed. The router response timed out"
What do the LED indicators on your device indicate?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Look for the LED
descriptions. Further reading might also be helpful.
colnhausen
Feb 10, 2019Aspirant
Yes, it's a nighthawk c7000 v1. My desktop is a HP. My ISP provider didn't provide the modem/router so they won't manage the device. I tried to update via nether software, web and mobile app (not compatible with remote managment.)
- antinodeFeb 10, 2019Guru
Ok. Then only your ISP can update its firmware.
> [...] My desktop is a HP. [...]
I'll assume that that means some version of Windows.
> [...] My ISP provider [...]
Which is?
> [...] didn't provide the modem/router so they won't manage the device.
> [...]That doesn't matter. This complaint appears here repeatedly, and the
answer is always the same:https://kb.netgear.com/000036375
If your firmware is outdated, you cannot manually upgrade your
cable modem's or modem router's firmware. You must contact your
Internet service provider (ISP) to upgrade your firmware.> [...] I tried to update via nether software, web and mobile app (not
> compatible with remote managment.)I don't know what that means.
