19delta
Oct 24, 2020Aspirant
Error on my new modem
Hello, any help here would be awesome. I just got my new modem a month ago (CM1200) and i have a Linksys MR9600 Series wifi router connected to it. I have the gig internet from xfinity and was downl...
Oct 24, 2020Guru - Experienced User
are you hardwired into the modem or router?
Make sure your testing from the modem to ensure the slowdown isn't the router.
do you have a screen snip of the cable connections page? Take one and post it back here.
Your logs indicate a line issue but the cable connections page helps.
If you have any splitters, amplifiers, or attenuators in the coax line, remove them.
