dkrl
May 04, 2019Follower
Ethernet connection issues CM1150V
Just purchased modem CM1150V, using OSX, Xfinity internet; in the past with other cable modems, I have always used a direct ethernet connection to my Mac through one ethernet port, and then connected...
antinode
Jun 23, 2019Guru
> Fairly snarky reply. [...]
Fairly incomplete/uninformative problem description.
> [...] three ethernet ports that don't do what most people would assume
> they do [...]
You're far ahead of me. I haven't surveyed enough people to know
what "most people would assume". When confronted with multiple Ethernet
ports on a _modem_ (not a router), my first reaction would be to get
some documentation which explained how to use them. Which I did.
> [...] When the ad on Amazon states [...]
_Whose_ "the ad on Amazon"? Not my fault.
> [...] knowing Xfinity only has one IP per household and requires
> routing for additional devices, it isn't very clear that it cannot do
> this.
Who's "knowing" this? I know nothing, but I might guess that Xfinity
offers some level of service which involves a block of IP addresses.
I'd expect typical residential service to provide one IP address. So
I'd expect a _modem_ not to be able to improve upon that.
> [...] Go to the link it points to for support and find something,
> ANYTHING, that explicitly says those ports cannot be used to connect to
> another device. [...]
Go to that link and find _anything_ which supports your assumption?
> [...] where the cable comes into my house is a terrible place for a
> wifi router, [...]
There are many ways to run (co-ax or Ethernet) cable from one place
to another, and many ways to disribute wireless-network signals in a
large building.
I gather that you bought a device which does not meet your
expectations, and you are unhappy. You seem to believe that those
expectations were reasonable, but they've proved to be wrong. If you
believe that you were misled, then you might direct your complaint to
the folks who led you. I'm not sure what you expect anyone in this
(mostly) user-to-user forum to do.
tencentgolf
Jun 23, 2019Initiate
Ok champ, thanks for being super helpful to people.
I am neither unhappy or happy, the netgear owner posting on amazon was unclear, the user manual even less clear, the support page completely void of any thing helpful. I solved it another way, not a big deal.
Your responses win for least productive on this forum. Hats off I guess.
- WafireAug 02, 2019Initiate
Having just set up the CM1150V, I ended up on this thread looking for an answer to the same issues as above. Now I know, and yes, I agree, pretty snarky initial reply.
- AbnrmalchrisDec 07, 2019Aspirant
How did you figure it out? Or get around?
- antinodeDec 07, 2019Guru
What is "it"? "get around" _what_?
The CM1150V is a modem, not a modem+router. If you're like most
users (in that you get one IP address from your ISP) and if you want to
have multiple devices on your LAN, then you need a router (as well as a
modem). If you don't have a router, and you need a router, then one
solution is to get a router. It's not complicated.
