dkrl
May 04, 2019Follower
Ethernet connection issues CM1150V
Just purchased modem CM1150V, using OSX, Xfinity internet; in the past with other cable modems, I have always used a direct ethernet connection to my Mac through one ethernet port, and then connected...
Jun 23, 2019Guru - Experienced User
The CM1150v is mostly for having just 1 PC connected or just 1 external wireless router. The additional LAN ports on the 1150v are for static assigned IP addresses from a ISP for mostly a business operation configuration. Or you can connect a LAG compatible router to the CM1150v and use Link Aggregation for bandwdith support. Such as the R7960P which supports LAG on it's WAN side. Again, mostly seen in a business environment.
If your a home user, I recommend getting into any external router and connect all client devices to the router. Use the 1150v modem for your internet service interface and phone support for you phone support needs.
dkrl wrote:Just purchased modem CM1150V, using OSX, Xfinity internet; in the past with other cable modems, I have always used a direct ethernet connection to my Mac through one ethernet port, and then connected my router from a second ethernet port. Netgear customer support said that I can not use that setup with this modem--I can either have the direct connection to the computer OR the connection to the router, but not both. Is this correct? This is the first time I have ever not been able to have both the computer connected directly by ethernet, and the router connected via a second port.
ojwoody
Jun 27, 2019Initiate
I completely understand what you're saying. There's absolutely no purpose for the other 3 ports because you cannot use them. One device one port, makes no sense to have the other three not sure why they would even put them there to confuse peopleI,
- FURRYe38Jun 28, 2019Guru - Experienced User
Well I presume this information is in the user manual and how to connect the modem up.
The ports are there for those configurations that support them is all. I presume the ports should be more clearing marked for home users in regards to only using the 1st port.
