dkrl
May 04, 2019Follower
Ethernet connection issues CM1150V
Just purchased modem CM1150V, using OSX, Xfinity internet; in the past with other cable modems, I have always used a direct ethernet connection to my Mac through one ethernet port, and then connected...
MacroLogo
May 21, 2020Aspirant
I had a very similar problem. I ultimately solved it by having my entire system connected as I wanted it (i.e., the ethernet cable connected between the cable modem and the wifi router), with everything powered on, then called Comcast/Xfinity on my cell phone. I verbally spoke the option "no internet connection" when the robot asked me to describe my problem at which point the robot reset my entire system remotely. It sent me a text message saying it was starting the reset and then hung up on me. Ten minutes later I got a message that my system had been reset. At that point, I was able to go through Netgear's protocol of setting up my new Wifi router, which included updating the Wifi router's firmware. It was however, obvious as soon as Xfinity had reset my system that things were going to work.
Further comments
1. I spent many hours trying to troubleshoot this before hitting upon the relatively quick solution above.
2. I called Comcast/Xfinity twice before my successful call. For these first two calls I had said I need to "Activate my system". Each time I was connected to a human. The first human got my information then tried to transfer me to an activating agent at which point my call was dropped by Comcast. The second agent insisted that I did not need to activate, said she had been working for Comcast for 20 years, that she could not possibly be wrong, and hung up on me. So the trick was getting a robot, not a human.
3. Comcast documentation and human advice seem to convey that once the cable modem is working, it doesn't matter what is hooked up downstream. This is demonstrably false. I was able to hook up only one device at a time (my old wifi router, or my computer directly, or my new wifi router, or another computer). In order to swap these out, I needed to use my cell phone to call Comcast and have the robot reset my entire system. In the case of directly connecting a computer, there was a way to do this directly form the computer browser, but I couldn't figure out how to do this directly with a wifi router.
4. Before hitting on the correct solution, I tried a number of tricks, like setting a static IP to the router equivalent to the IP that Comcast had previously assigned my desktop computer. But I was not successful.
5. I was getting close to giving up an surrendering and buying an Xfinity Gateway. Xfinity definitely has a conflict of interest in providing advice or making it easy to connect your own gear.
6. It wasn't strictly true that I had "no internet connection" because I did have a connection through my desktop computer. I just couldn't figure out how to change that connection to the wifi router.
7. I was not able to update the Netgear Nighthawk router's firmware until after I had the system reset by Comcast.
8. Merely turning off the power to the cable modem does not work. It has to be reset remotely by Comcast.
May 21, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
You can factory reset the CM modem your self as well. There is a reset button on the modem. Press and hold it for 15 seconds then release.
