Retired_Member
May 07, 2022Ethernet downloading slow with NETGEAR Nighthawk DOCSIS 3.1
I have a fast internet connection via Xfinity, which goes through my Nighthawk and then wirelessly through Google Nest. As far as I can tell there are no issues with Xfinity, Nest or the Nighthawk wh...
- Retired_MemberMay 08, 2022
Why would you come on here to chastise someone who needs help for an error that someone else has already corrected, and not offer any help yourself?
It's OK: the answer is obvious. You are a petty individual with not much going for you in the rest of your life, so you troll places like this looking for an opportunity to feel better about yourself.
Hope it worked for you for a few minutes.
By the way, I fixed the problem I came on her for without you. Good luck fixing yours. You probably need a different kind of forum for that.
michaelkenward
May 08, 2022Guru - Experienced User
Retired_Member wrote:
Apologies -- didn't realize there was more than one Nighthawk. It's the CM2050V.
That is a modem only device. Most of the features and performance is down to the router between the modem and your network.
Saying "Google Nest£ is about as detailed as saying Nighthawk. Both are brands rather than model numbers.
Retired_Member
May 08, 2022Why would you come on here to chastise someone who needs help for an error that someone else has already corrected, and not offer any help yourself?
