Crashnburnps3
Feb 11, 2019Aspirant
Ethernet Port activation
Model:1150V NightHawk Voice Cable Modem
Hello I have a question that the documentation for this modem cant seem to answer. I was wanting to connect a second router to this modem since it has 4 port...
Nodism1125
Feb 11, 2019NETGEAR Expert
Hi Crashnburnps3,
Ethernet ports 2-4 are covered on your Nighthawk CM1150V Voice Cable Modem because those ports are reserved for Ethernet port aggregation. Ethernet port aggregation is not currently supported for the CM1150V.
- TimGSMar 14, 2019Guide
The CM1150V has only 1 usable port even though it physically has 4 total Ethernet ports; this appears to be a bit of false advertising. :(
- CatchenreMay 25, 2019AspirantI agree, this kind of false advertising is completely unacceptable and I'm pretty pissed.
- CatchenreMay 25, 2019AspirantWhy even have ports for aggregation if it isn't supported!?
- KevomanSep 30, 2019Initiate
It isn't false advertising, know what you are buying.
- goofy78270Sep 30, 2019Aspirant
https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
So tell me how it is not false advertising when they say "Gigabit Ethernet ports (with LAN port aggregation) for faster wired connections" or "Gigabit Ethernet Ports—Four (4) Gigabit Ethernet ports (allows 2 LAN port aggregation to double maximum wired speeds)." but the feature is not available at this time.
