Crashnburnps3
Feb 11, 2019Aspirant
Ethernet Port activation
Model:1150V NightHawk Voice Cable Modem
Hello I have a question that the documentation for this modem cant seem to answer. I was wanting to connect a second router to this modem since it has 4 port...
Jul 29, 2019Guru - Experienced User
Ya I understand. I think there needs to be more in front customer information regarding how the these modems work and what they really do for users. Customers need the correct information to made better buy discisions. The average home user really doesn't have a need for the additional ports. :smileywink:
goofy78270
Sep 10, 2019Aspirant
I also agree that the choice for aggregation should be up to the user. Most home users do not even know what this is. Even with the link aggregation, which they currently advertise for this modem, but is not available (https://kb.netgear.com/000060510/Why-are-three-Ethernet-ports-covered-on-my-NETGEAR-Nighthawk-CM1150V-Voice-Cable-Modem#), it states only 2 port aggregation...so why are there 4 ports if not for additional devices or 4 port aggregation.
Excerpt from Netgear product page - https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
> Use an Ethernet cable to connect the CM1150V cable modem Ethernet ports to WAN port of your existing WiFi router, WiFi System or directly to your computer and get high-speed connectivity for all your devices. Aggregate two (2) LAN ports to double maximum wired speeds (compatible WiFi router like the Nighthawk AX8).
I also talked with the Xfinity rep about this modem and while multiple IPs is an option from them, there is currently no interface within the modem to setup static ips so flipping between IPs may be a problem upon reboots (manual or after auto firmware updates). Also, this in turn comes at an additional $10 a month. Why would I not just use the cable modem from Comcast at $13-$15 a month versus the $10, and have 4 ports that ALL work, includes XFi, and wireless, with no additional devices needed?
Netgear, I have loved most of your products, and been a big fan for a while but this is pushing me away as this product is advertised to replace an Xfinity modem, but loses so many features and is not really a replacement as I am replacing 1 device with 3 others.
When will link aggregation be supported or the additional ports enabled for a single IP address as this product has been on the market for about a year now?
- FURRYe38Sep 10, 2019Guru - Experienced User
Most home users only have a need for 1 IP address. The LAG support and multi IP address support is meant for business class envrinoments. The 1150v seems to support both home and business environments and seems to be designed for this kind of flexibility. It's up to the user to deside there needs and if this modem fits that or not.
