Crashnburnps3
Feb 11, 2019Aspirant
Ethernet Port activation
Model:1150V NightHawk Voice Cable Modem
Hello I have a question that the documentation for this modem cant seem to answer. I was wanting to connect a second router to this modem since it has 4 port...
goofy78270
Sep 30, 2019Aspirant
https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
So tell me how it is not false advertising when they say "Gigabit Ethernet ports (with LAN port aggregation) for faster wired connections" or "Gigabit Ethernet Ports—Four (4) Gigabit Ethernet ports (allows 2 LAN port aggregation to double maximum wired speeds)." but the feature is not available at this time.
Oct 01, 2019Guru - Experienced User
I believe NG already mentioned that LAG is coming to the 1150v modem.
LAG is already supported on the CM1100 and 1200 modems.
