micselafey
Jan 27, 2023Aspirant
ETHERNET PORT NOT WORKING
I have an AC1900 Cable Router and 1 of the 4 ethernet ports has stopped working. It actually switches ports because I've had to unplug/replug my DTV several times into a different port. Way out of wa...
Jan 29, 2023Guru - Experienced User
You can test ports on them. Usually they way you are with just having a device connected to it.
have you tried swapping the ethernet cable between 2x devices to see if its a port issue, a device issue, or a cable issue?
micselafey
Jan 29, 2023Aspirant
Thanks for the reply. After watching it after I posted it may be the DVR. That is the only thing that doesn't work then I switch the cable to another port and it reconnects. Going to drop DTV soon anyway so we'll see.
Thanks, Mike
