Nareska
Jun 09, 2021Aspirant
Ethernet port switch
My router/modem combo has two ethernet ports, I need three to four. I was looking at getting a ethernet port switch and was wondering if I can just plug it into one of the ethernet ports or if I need...
Nareska
3700v2 is what it says next to model and I see nothing else labled as model or model number on the router. Sorry if I'm missing something I just don;t see where it would be aside from the spot labled model.
It refers to an ethernet port switch. Basically wonder if I just plug an ethernet cord into an ethernet port on the router and into the back of the switch
antinode
Jun 09, 2021Guru
> 3700v2 is what it says next to model [...]
Look again? "3700v2" and "WNDR3700v2" are spelled differently for a
reason. "C3700v2", perhaps?
Visit http://netgear.com/support , put in what might be your model
number, and look for Documentation. Get the User Manual (at least).
Read. Count the Ethernet ports in the manual.
> [...] Basically wonder if I just plug an ethernet cord into an
> ethernet port on the router and into the back of the switch [...]
Should work.
- NareskaJun 09, 2021Aspirant
That's entierly my bad, I didn;t think the c meant much of anything it is the c3700v2 I'll ceck the document area thanks!
Edit: I don;t see anything about a switch or anything but I'll grab one from walmart and see if it works, thanks again!- antinodeJun 09, 2021Guru
> one from walmart and see if it works, thanks again!The manual for a WNDR3700v2 would show you more than "two ethernet
ports". Otherwise, not much use in this context.Practically any cheap-Chinese Ethernet switch with enough ports and
"gigabit" or "1000" in its description should be good enough.
> [...] I didn;t think the c meant much of anything [...]In the words of the philosopher Williams, "If you don't think too
good, don't think too much."
