m4w
Oct 30, 2017Aspirant
Ethernet ports dead slow
Hi, from very beginning the ethernet ports of this c7100v have been dead slow (at 4-6Mbps), while wifi gets the full 50Mbps. Saw the entry about QoS, but coudn't find qos anywhere in the router ...
vkdelta
Oct 30, 2017NETGEAR Employee Retired
what is your actual provisioned speeds?
what device are you testing with?
which website are you testing with?
there is not router qos on the Cable devices.
It supports DOCSIS QoS but it is configured by the ISP to prioritize your voice packets.
m4w
no specific website, but Mlab speed test.
actual measured speed wifi: 67Mbps
actual measured speed ethernet: 5.5Mbps
Measurements both with the same Widows 7 laptop (Dell XPS L502x), 20 sec apart (time to disconnect wifi and connect cable)
