liduck
Jul 23, 2019Tutor
Ethernet ports not working after ISP outage R6400
Had bad storms pass through area yesterday and experienced ISP outage (internet/TV/phone). Went to work and came home to find ISP service restored, wifi is up and working but all of the ethernet por...
- Jul 23, 2019
> [...] no mention of NO light lit, [...]
No port-status light = no connection.
If you had even one working port, then you could connect it to an
external network switch, but if they're all fried, then you may be
doomed.> [...] as it's past the 3 months, the only help I can get from Netgear
> is to buy a contract? [...]I wouldn't bet that the warranty covers lightning, but there should
be an option to return a defective gizmo without needing a support
agreement.
antinode
Jul 23, 2019Guru
> Had bad storms [...]
That sounds more like a cause than "ISP outage" (which sounds like
another effect).
> [...] IIRC, they should light up when I plug in an active device.
No need to recall. Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Read.
Connecting a known-good Ethernet cable between any two LAN ports
should give you two good port-status indicators, too.
> [...] Only thing left to do is to a full factory reset, [...]
You can try that, but I'd guess that your hardware is fried, and a
settings reset won't help that.
> [...] Was able to log into my router, [...]
How, wirelessly?
> [...] firmware is up-to-date. [...]
As always, an actual version number would be more useful than your
opinion of what's "up-to-date" today. But, in this case, it probably
matters little.
- liduckJul 23, 2019Tutor
antinode wrote:> Had bad storms [...]
another effect).I'm afraid of that too, but I have to try
> [...]No need to recall. Visit http://netgear.com/support , put in your
model number, and look for Documentation. Get the User Manual. Read.Connecting a known-good Ethernet cable between any two LAN ports
should give you two good port-status indicators, too.Did that earlier but no mention of NO light lit, nor mention of this in the troubleshooting section for this router
settings reset won't help that.Indeed, no joy
How, wirelessly?Yes, it works flawlessly from the get-go wirelessly, just no luck with the ethernet connections, which I was hoping I could revive with some unpublished command, but it looks like out of luck.
matters little.V1.0.0.50 and it didn't matter. Still no luck with the cables and as it's past the 3 months, the only help I can get from Netgear is to buy a contract? And thanks for the responses Antinode and FURRYe38!
- antinodeJul 23, 2019Guru
agreement.
