paulrjacobs
Dec 09, 2020Tutor
Ethernet Ports not working
I have a C7000v2. Ethernet Port 1 is always green even if nothing is plugged into it. I never show any device that's plugged into any of the ports under 'Wired' in 'Attached Devices' even with many...
Dec 09, 2020Guru - Experienced User
If you disconnect all wires including the coax cable, pull the power cord from the wall out late for 30 seconds then plug back in, does this change anything?
- paulrjacobsDec 09, 2020Tutor
Worth a shot but no dice :-(
- FURRYe38Dec 09, 2020Guru - Experienced User
with call cables disconnected, press the reset button for 15 seconds then release?
- paulrjacobsDec 10, 2020Tutor
Why would this fix a green light on port 1 that stays on even when no cable is in the port?
