dcarey1964
Jun 22, 2020Aspirant
Event log CM 1000
Is there anyone the can look over my event logs and give me so insite on why it keeps going down 2 or 3 times a day. Cox support says it's my equipment.
Jun 22, 2020Guru - Experienced User
Do you also have a screen snip of the cable connections page? it helps to have them both to compare.
many of your errors/warnings are related to signal issues. That's where that cable connections page can help.
if you have any splitters, attenuators, or amplifiers in line, remove them.
dcarey1964
i do have a splitter and i downloaded the cable connection log
- plemansJun 23, 2020Guru - Experienced User
you also need the upstream info. and ofdma
