Sigmaerr
Jul 21, 2021Follower
Everything should be working, no connection. Linksys ea6350 Netgear cm6000
I am using a Netgear CM6000 modem and a linksys ea6350 router connected to it with an ethernet cable. All lights on the netgear modem are solid green, except the ethernet light which is green and flashing as normal. The linksys router is also green, but when I connect to the WiFi there is no internet.
I thought the issue might have something to do with the fact I changed to dynamic routing in linksys settings, but when I try to change it back, it wont let me open the linksys portal website even when I am connected to the WiFi.
Is this a problem with netgear, linksys or my ISP?
1 Reply
Power OFF the CM modem and connect 1 wired PC to the modem. Power ON the modem. Check internet sevices here first. Get internet? If so, then your problem would be with Linksys.
If you don't get anything thru the CM modem with the 1 wired PC, possible problem with ISP or modem or PC.
