yahdoneson1247
Sep 22, 2021Guide
Experiencing packet loss and loss connection
Wed Sep 22 17:45:55 2021 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=28:80:88:b3:ac:f0;CMTS-MAC=00:01:5c:a6:46:59;CM-QOS=1.1;CM-VER=3.1;
Wed Sep 22 16...
yahdoneson1247
Sep 22, 2021Guide
Apply Cancel Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency 0 Startup Procedure Procedure Status Comment Acquire Downstream Channel 759000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enabled BPI+ IP Provisioning Mode IPv6 Only ipv6Only(1) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 20 759000000 Hz 5.7 dBmV 37.4 dB 46 0 2 Locked QAM256 2 651000000 Hz 5.9 dBmV 38.4 dB 81 0 3 Locked QAM256 3 657000000 Hz 5.8 dBmV 38.2 dB 77 0 4 Locked QAM256 4 663000000 Hz 5.8 dBmV 38 dB 86 0 5 Locked QAM256 5 669000000 Hz 6.1 dBmV 38.1 dB 78 0 6 Locked QAM256 6 675000000 Hz 5.9 dBmV 37.8 dB 75 0 7 Locked QAM256 7 681000000 Hz 5.9 dBmV 38 dB 100 0 8 Locked QAM256 8 687000000 Hz 6 dBmV 38 dB 91 0 9 Locked QAM256 9 693000000 Hz 5.8 dBmV 37.9 dB 85 0 10 Locked QAM256 10 699000000 Hz 5.8 dBmV 38 dB 67 0 11 Locked QAM256 11 705000000 Hz 5.9 dBmV 37.9 dB 69 0 12 Locked QAM256 12 711000000 Hz 5.9 dBmV 37.9 dB 67 0 13 Locked QAM256 13 717000000 Hz 6 dBmV 37.8 dB 80 0 14 Locked QAM256 14 723000000 Hz 5.7 dBmV 37.6 dB 60 0 15 Locked QAM256 15 729000000 Hz 5.7 dBmV 37.6 dB 64 0 16 Locked QAM256 16 735000000 Hz 5.7 dBmV 37.6 dB 62 0 17 Locked QAM256 17 741000000 Hz 5.8 dBmV 37.7 dB 56 0 18 Locked QAM256 18 747000000 Hz 5.8 dBmV 37.7 dB 89 0 19 Locked QAM256 19 753000000 Hz 5.8 dBmV 37.6 dB 65 0 20 Locked QAM256 21 765000000 Hz 5.5 dBmV 37.5 dB 50 0 21 Locked QAM256 22 771000000 Hz 5.5 dBmV 37.4 dB 66 0 22 Locked QAM256 23 777000000 Hz 5.5 dBmV 37.6 dB 122 19 23 Locked QAM256 24 783000000 Hz 5.4 dBmV 37.4 dB 158 8 24 Locked QAM256 25 789000000 Hz 5.5 dBmV 37.3 dB 60 0 25 Locked QAM256 26 795000000 Hz 5.4 dBmV 37.2 dB 52 0 26 Locked QAM256 27 801000000 Hz 5.3 dBmV 37.2 dB 58 0 27 Locked QAM256 28 807000000 Hz 5.2 dBmV 37.1 dB 48 0 28 Locked QAM256 29 813000000 Hz 4.9 dBmV 37 dB 51 0 29 Locked QAM256 30 819000000 Hz 4.9 dBmV 36.9 dB 46 0 30 Locked QAM256 31 825000000 Hz 4.9 dBmV 36.8 dB 63 0 31 Locked QAM256 32 831000000 Hz 5 dBmV 36.7 dB 77 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 5 5120 Ksym/sec 17800000 Hz 45.3 dBmV 2 Locked ATDMA 6 5120 Ksym/sec 24200000 Hz 45.5 dBmV 3 Locked ATDMA 7 5120 Ksym/sec 30600000 Hz 46.8 dBmV 4 Locked ATDMA 8 5120 Ksym/sec 37000000 Hz 47.8 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Downstream OFDM Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0 ,1 ,2 1 338000000 Hz 5.0 dBmV 40.7 dB 148 ~ 3947 1513168518 1444509750 52297 2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0 Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked 0 0 0 Hz 0 dBmV 2 Not Locked 0 0 0 Hz 0 dBmV Extended Upstream Transmit Power Enable Extended Upstream Transmit Power Current System Time:Wed Sep 22 18:54:26 2021 System Up Time:1 day 02:28:57
Here are my other values from cable connection.
