My_Username
Nov 17, 2021Apprentice
Extended upstream transmit power - CAX80
Cable diagnostics say I have a poor connection due to upstream power. See diagnostic output below. I see that extended upstream transmit power is checked. I can click on the setting but nothing chan...
Dec 12, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
