brettdotcom14
Dec 19, 2021Aspirant
factory reset after power failure CAX80 RAX50
every time i have a power failure my cax80 loses my cable company info as well as my admin login security question and any other settings. same goes for my rax50 which i only have setup as an access ...
brettdotcom14
Dec 21, 2021Aspirant
Both came with the latest firmware installed.
ISP is optimum
On the router I did do one factory reset because I forgot the password. Then reset everything and had a power failure and everything reset to square one
I don’t believe I ever did a factory reset on the cax80
Do you need the firmware numbers? I just know when I search for an update they say they’re the latest
ISP is optimum
Dec 22, 2021Guru - Experienced User
Please give FW numbers...
Can you try the CAX in modem mode and the RAX in router mode?
FYI, I also noticed this on my CAX80 the other day. I just did a reboot of the modem from it's web page and connected Orbi router lost internet access. I had to reset and setup the CAX80 from scratch.
- brettdotcom14Dec 22, 2021AspirantThe cax80 is V2.1.3.5
The rax50 is V1.0.4.100
I can try setting it up that way. I wanted the rax50 to the an access point to extend my Wi-Fi
