Joshbseen
Jul 04, 2022Aspirant
Factory reset C3000, have internet but can't access router wifi network
So I did a factory reset on an C3000 N300 wifi cable modem router combo. We have 3 computers connected; 2 via wifi and 1 via ethernet. All 3 can launch browsers and access various web sites....
Jul 05, 2022Guru - Experienced User
Try going to 192.168.100.1
Also, make sure IPv6 is enabled.
Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
CloudFlare 1.1.1.1 and 1.0.0.1
GoogleDNS 8.8.8.8 and 8.8.4.4
- JoshbseenJul 05, 2022Aspirant
Hey thanks for responding.
That IP address sent the same message of "not connected to router's wifi network." This is on an ethernet connection.
I tried with both a Google and Cloudflare dns on the pc end.
Is this an ISP issue? I have factory reset before and never, to my memory, had this issue before. I run through Comcast, so just the thought of contacting customer service depresses me.
- plemansJul 06, 2022Guru - Experienced User
Try factory resetting 1 more time. But disconnect the coax cable from the modem. Then push and hold reset for 7-15 seconds while powered on.
Then try and connect and follow the install guide.
Try using a windows pc if you're on mac/ios
- JoshbseenJul 06, 2022Aspirant
Yeah I did all that.
I even contacted the ISP. They did a reset on their end and confirmed the modem/router had no issue from their side.
Established the modem/router has gone into critical failure mode.
Purchased a Nighthawk AC1900 wifi cable modem router and am currently enjoying quite an improvement to internet speeds and functions all around.
Thank you for responding. I posted everywhere and you where pretty much the only one that chimed in.
